Re: It's my turn to convert...
Good Luck!
For you, figuring the gallons had only ONE thing you didn't know from Middle School geometry--7.48 gallons per cubic foot. And I'll bet you didn't even realize you knew it all the time!
I have never done a Baq conversion. I gather it's pretty scary and you are going to use ALOT of LC on the way...but once you are there, you'll never look back.
BTW, if you have a sand filter,when your conversion is complete, dump and replace your sand. It's one of the very, very VERY few times we recommend that.
I don't know if you can clean a cartridge after a convert or if you must replace it (OUCH!--sand is CHEAP, so replacement doesn't hurt)
But of course you should be able to clean a DE filter's screens and/or fingers.
