Results 1 to 10 of 15
Thread: Will adding borax to 50ppm kill Mustard algae
    Unhappy Will adding borax to 50ppm kill Mustard algae
    I am having a hell of a time this year with Mustard algae.
    I think I'm gonna add Borax to 50ppm asper the posts I have searched.
    Will this kill off the algae or must I kill it before I add the Borax?
    How much Borax and how much acid will I need to reach 50ppm?
    I come up with 34 LBS. Borax & 2 GALS., 17oz. of acid.
    Could I try Seaklear Algae Prevention & Remover or SeaKlear Yellow Klear and if so, Which? I'm kinda leaning towards the Algae Prevention & Remover.
    Thanks for any help!
    Darrell W. -------------------------------------------------------------------
    Man!,this water is cold!
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Default Re: Will adding borax to 50ppm kill Mustard algae
    Quote Originally Posted by fuelman View Post
    This is chelated copper sulfate. I would not recommend it, although copper is the ONLY algaecide that actually kills algae besides chlorine and bromine. All the others just inhibit it.
    This is sodium bromide. It would be my first choice but be very careful NOT to overdose. It will take repeated shocking before your FC holds since it temporarily converts the pool into a bromine pool. This is an effective product if your CYA is high and not as effective if it is in normal range. If you have mustard algae then I suspect that you either have higher than average CYA or you are not maintaining your FC.
    If you would post a full set of test results I could make a better recommendation. Often plain chlorine is all that is needed but with a vinyl pool you will have to bring the levels up fairly high and might suffer some bleaching of the liner.
    The borates, to the best of my knowledge, won't really kill the mustard but are very effective at inhibiting it once it is under control. However, I don't know for sure so it could be a worthwhile experiment. I seem to recall some people on this forum saying last year that borates were the only thing that kept the mustard from returning but I don't know if that is what they used to kill the outbreak.
    Are you SURE that you have mustard and not pollen? They are often confused and I noticed that you have in your sig that your water is cold. Mustard is much more common later in the swim season when the temps are much warmer.
    Waterbear,
    here are my numbers;
    TC-3.0PPM
    FC-3.0PPM
    CC-0.0PPM
    PH-7.8
    TA-125PPM
    CH-175PPM
    STA.-50PPM
    TDS-3600PPM
    SALT-2500PPM
    PHOS-500
    That TDS & PHOS level is kinda high ain't they?
    The water has a salty taste to it.
    What do you recommend?
    oh, by the way, my sig."Man!,this water is cold! is just me trying to be funny.
    9,240 Gallon
    Daytona Beach,FL.
    Waterbear,
    TC-3.0PPM
    FC-3.0PPM
    CC-0.0PPM
    PH-7.8
    TA-125PPM
    CH-175PPM
    STA.-50PPM
    TDS-3600PPM
    SALT-2500PPM
    PHOS-500
    Do you have a SWG? If so, what kind? Salt level of 2500 is below the taste threshold (and too low for most SWGs to operate well, which could be the reason for the Mustard, along with a CYA of only 50 ppm, which is also low for a SWG. Your TDS is only 1100 ppm above your salt so that is your actual TDS (which is a bogus measurement anyway). Phosphates are a non issue in 99% of cases. Mine ore over 3000 ppb!
    Nope, I don't have a SWG.
    I have thought about one but I haven't jumped on board that train.
    I have only ever added a mixture of city water and well water at the first fill, then only city water since to keep the level. Bleach, liquid Chlorine, baking soda, Muriatic acid, Yellow-out, and about 4 doses of all-in one algaecide till I found this site.
    I take it that the salt level is from the bleach?
    The pool has only been up and running since 8/06.
    Thanks for your help
    9,240 Gallon
    Daytona Beach,FL.
    BUMP for answer to above
    9,240 Gallon
    Daytona Beach,FL.
