Results 1 to 10 of 15
Thread: Will adding borax to 50ppm kill Mustard algae
Threaded View
    Default Re: Will adding borax to 50ppm kill Mustard algae
    confused a bit by your test results. If you don't have a SWG then why are you testing for salt at all?
    I am also a bit concerned by the fact that you have no CC yet you think you have mustard algae. If there was mustard in the water you would have some CC. How was your water tested? something does not seem right.
    Waterbear, My neighbor has a SWG and a very expensive Taylor K-1741-C test kit. The Mustard algae turned out to be pollen. As for the salt test he just tested it out of habit. The phos level and the TDS level was tested at the pool store.
    I have been using a lot of bleach lately, 1/2 gallon a day. Seems more than I used last year. Do you have any idea why?
    Darrell W. -------------------------------------------------------------------
    Man!,this water is cold!
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
