You don't necessarily have to backwash every week. You just watch the pressure on your filter's guage and when the pressure rises 8-10 psi over your clean filter pressure you backwash. Backwashing is a simple process that involves turning a handle on your filter from the "filter" setting, to the "backwash" setting and letting it run for a minute or two until the water is no longer muddy looking. You then turn the handle to the "rinse" setting and let it run for about 15 seconds. Then, back to the 'filter' setting. That is it. The whole process takes about 2 or 3 minutes. Can't get much more simple than that. (Reminder --- always turn the pump off before turning the handle from one filter setting to another.) Sound easier than cleaning a cartridge filter??![]()
