Re: Starting the conversion... and have questions.
Thanks guys.
JayC, my pool is a 15x30 oval 4' of water depth with a sand filter. I don't know the Baq levels before I started, I just went and jumped into the conversion.
In the fall I didn't put in the full amount of Baq the directions stated. I knew I was going to convert in the spring, but didn't want the water to go all winter without anything in it. I refilled about 15" of water before I added any bleach, so I'm thinking if there was much Baq left, maybe the fresh water would have helped use it up.
Carl, I'm sure my 'Junior Memberness' is showing
, but are there 2 indicators that tell me when conversion is complete?
1. FC holds overnight, and
2. CC is less that .5
Thanks, and boy did my wife get some strange looks buying all that bleach....
