Results 1 to 3 of 3
Thread: noise
    timmie is offline Registered+ Thread Analyst timmie 0
    manitoba, canada
    Default noise
    Hi, can anyone tell me why my eyeballs in the pool make so much noise when water is coming out??All myequipment is new since last fall. The other thing is I have this red handle for my Heyward pump, do I need to turn that off before I backwash??
    Attleboro, MA.
    Default Re: noise
    Usually for me when the return makes noise there is air in the system. This happens when the water level in the pump drops.
    Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
    Smile Re: noise
    Timmie, any chance that the noise you are hearing is from the water breaking the surface? - if so, point the eyeballs down a little. I think the red handle you are talking about is on line coming into the front of the pump, if it is you don't have to change it to backwash the filter - it's there to adjust the flow from your 2 suction sources (like for vacuuming) or keep the prime in the pump when you empty the strainer basket in the pump (if the pump is significantly higher than the water level)
    HTH
  1. Ozonator noise
    By ovonick in forum Pool Equipment & Operations
    Last Post: 07-20-2011, 08:31 PM
  2. Sucking Noise
    By Sue225 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-07-2010, 12:20 AM
  3. pump noise
    By aubratgyrl in forum Pool Equipment & Operations
    Last Post: 05-06-2009, 08:53 PM
  4. whoosing noise
    By timmie in forum Pool Equipment & Operations
    Last Post: 06-04-2008, 04:26 PM
  5. Pump noise
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 10-13-2006, 07:18 PM
