Thread: Target Numbers
    Mahwah, NJ, USA.
    Default Target Numbers
    I remember seeing an estimate for target CL, ALK, PH, CYA. etc.
    Searched the forums and could not find it. Can someone point me in the right direction?
    thanks
    Default Re: Target Numbers
    Check the stickied threads in various forums, especially those begun by any of the moderators--CarlD (me), Poconos, Watermom, or aylad. Also by PoolDoc.
    I'll give you numbers I like:
    pH: 7.2-7.8
    T/A(Total Alkalinity): 80-120ppm
    Calcium: 200- 400ppm (but not relevant to vinyl pools)
    CYA/Stabilizer: 30-50ppm
    Ideal Chlorine levels are determined by CYA levels. AT MY PREFERRED CYA LEVEL... FC (Free Chlorine): 3-6ppm
    CC (Combined Chloramines): 0 ppm (no matter the CYA level).
    But if your CYA level is 100ppm, you MUST maintain a Free Chlorine level of 8-15ppm.
    For the relationship between CYA and FC, see the "Best Guess Table".
    T/A is tied to pH. If pH is high, then T/A will be higher. If pH is lower, then T/A comes down as well. Your TRUE T/A is what you measure at your ideal pH--and you adjust it based on that.
  1. My Numbers -
    By Hey_Dad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-06-2011, 04:43 AM
  2. what to do w/ these numbers?
    By denanbob in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2006, 10:41 AM
  3. New guy's numbers
    By wipple in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-29-2006, 12:23 PM
  4. Here's my numbers
    By nicoleh in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 12:32 PM
