I also usually lose all of my cya over the winter and have to add it each spring. But, I don't think that has anything to do with 'dull' water. Add enough cya per package directions to get to an initial level of about 30. You can either put it in a sock or stocking and tie it in front of a return or you can pour it into your skimmer slowly while the pump is running and then let your pump run 24/7 for a few days. That is what I do with my pool. Remember, it can take up to a week for cya to dissolve, so don't backwash (if you add it through the skimmer), test for it or add any more for up to a week. Otherwise, you may think you need more when you don't.
By the way, it is normal to lose some chlorine through the day even if you do have cya in the water. That just means the chlorine is doing its job sanitizing the water. Of course, once the cya is dissolved, your cl will not disappear as fast. For this week until it does dissolve, it is probably best to test your water morning AND evening and each time dose it with bleach. After about a week, you should be able to go to only testing and dosing in the evening. Good luck. Let us know if you have any further questions and we will try and help.
One last thing, keep an eye on your ph. Don't want to let it drop below 7.0. You are OK at 7.2. I typically like to keep mine a little higher --- somewhere between 7.4-7.6.
