Thread: weight of baking soda
    Default weight of baking soda
    Went to the pool store and they indicated i needed to add 9lbs of baking soda. I was told that 1 lb is equal to 2 cups, so i started by adding 6 cups which should be 3 lbs (per further instruction to break into 3 incremental doses). I am now thinking that the cup felt pretty heavy and am wondering if 2 cups is indeed 1 lb? I am fearful that I used too much and will overshoot which I am now reading would be an issue. TIA!
    Kentucky
    Default Re: weight of baking soda
    I've never measured it by the cup, but being familiar with the size of the 1lb boxes that I use for my pool I'd say 1 cup is = 1lb.
    Don't worry about overshooing unless you get a reading above 200ppm.
    Phantomandy
    18x36 IG Vinyl Grecian / Hayward H250 Heater / Hayward Sand Filter / Rainbow Trichlor Online Feeder / Treated using BBB and Trichlor Combo / Tested using the world famous (and now exclusive) PS233 Kit
    Quote Originally Posted by ekaifes View Post
    9 lbs??? What is it, a 45,000 gallon pool?
    Jul 2006
    Yeah, really. I have 44,000 gal pool and at start up only use 8lbs of baking soda
    The density of powdered baking soda (tapped in the cup) is around 1.2 g/ml (solid sodium bicarbonate is 2.2 g/ml). This means that 1 cup is 10 ounces and 1 pound is 1.6 cups. So you are right that it felt heavier than they indicated.
  1. Baking soda - too much?
    By Stacyf419 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-14-2012, 08:10 AM
  2. How much baking soda can I add in a day?
    By mwsigler in forum Dealing with Alkalinity and Calcium
    Last Post: 06-16-2007, 08:45 AM
  3. Baking Soda How To Add
    By msb1766 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2006, 09:39 AM
  4. How much baking soda?
    By thewayne in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 07:34 PM
  5. pH--soda ash vs baking soda
    By bbluvbasket in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-13-2006, 01:23 PM
