Thread: Switching Pool to SWG
    Newnan, GA
    Default Switching Pool to SWG
    Hi Everyone,
    I have a 2 year old 30' round AG vinyl liner pool which I want to go ahead and convert to SWG. This site has been an awesome resource on maintaining my pool chemistry. I finally piped in my SWG last week when I opened the pool and want to now go ahead and convert to salt and start using the SWG (Intellichlor w/ IC40) since it appears everything has stabilized. Any advice on adjusting chemistry per the current test results below would be appreciated. Additionally, what is the best way to determine the amount of salt to add since I understand that there is a present salt value associated with the the current B-B-B control methodology.
    ph- 7.3
    TC- 1.0
    FC- 1.0
    T/A- 90
    CH- 40
    CYA- 35
    Scottsdale, Arizona
    Default Re: Switching Pool to SWG
    Have your water tested to determine the current salt level and post that number along with the SWG recommended level. Also look to see what is recommended for your CYA level, it's probably goign to be higher that the current level.
