Results 1 to 10 of 13
Thread: Solar Blanket Differences?
    Default Solar Blanket Differences?
    Hey folks,
    I just ordered a Solar Blanket from Namco (chain pool store). It's 12 MIL and for an 18X36 pool it was on sale for $88. Lowes has an 8 MIL for about the same price. The Local pool store has a 12 MIL for $150.
    Few questions:
    1) Other than thickness, what other considerations are there when looking for a solar cover?
    2) I can still cancel my order, so is there any feature/attribute I should be looking for (that maybe the one from the Local Pool Store is giving me)?
    3) Is it true that the thicker the solar blanket, the better?
    Thanks a lot!
    bbb is offline Registered+ Thread Analyst bbb 0
    Default Re: Solar Blanket Differences?
    A lower quality solar blanket that is used beats a higher quality solar blanket that isn't used every time.
    My "from left field" response:
    The quality of the solar blanket *reel* is much more important than the quality of the solar blanket itself - so the reel is the best place to invest your money, in my opinion. My reel makes it easier for me to use the blanket every day -- and the savings I find with heat pump usage, decrease in evaporation, and decrease in chlorine usage/SWG power level are significant.
    There are advantages of clear vs blue vs black vs metallic, and there are already threads here that discuss them. The only negative I can think of for a thicker cover could be that it could weigh more and be thicker on a reel.
    bbb = bleach, borax, & baking soda
    I actually don't think I could buy a reel. I have an in-ground pool with a diving board on the end and a slide on the side. Because of the slide, I wouldn't be able to roll the reel along the pool.
    The guy at the pool store said that they don't make stationary reels for in-ground pools. Is that true?
    ***EDIT*** Just called them up and now a different guy is saying the opposite. That they do have stationary reels for in-ground pools and that the full kit is around $130 or so.
    I have a pool reel that is taller and goes *over* my diving board. I'll see if I can find a link to it
    Edit: ok, found the link.
    I use this, the HV 2000: http://www.poolsinc.com/sr_hv2000.html
    I have a ladder part way down. I don't roll the reel down the length of the pool - I usually only roll it out of the way of the diving board when the pool is in use, and leave it just inside the diving board end for rolling/unrolling.
    Also, mine sags, unlike what it says on the website there... but it doesn't affect operations much.
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    There are also low-profile reels for under the diving board.
    The thickness doesnt matter for heat retention, just for life of the cover.
    Thinner covers rip apart faster.
    Preventing evaporation is the goal for any cover. Accomplish that and you'll have a warmer pool. Colors make relatively minor difference.
    Some people have hobbies.....I have a pool.
    I disagree. I think thicker ones definitely retain heat better--and they "die" after 3 years just like the cheap ones.
    I've had opaque-blue-on-top-black underneath, transparent blue and clear. They all last maxium 3 years and the warranty isn't worth a bucket of backwashed water. It's only if it de-laminates, not if all the bubbles all fall off in your pool.
    I went from an expensive diamond 17mil clear to a blue transparent 12mil for just that reason--I'd rather spend $120 than $220 for a cover that will last 3 years.
    But a good reel is definitely worth it. I had one of those plastic ones and the bearings even were plastic. They tore up and made it nearly impossible to turn. Now I have a metal one with steel bearings and, in its third season, it's like it's brand new.
