Re: When to Change Cartridges
I was wondering if I should be soaking it in an acid/water solution. Does it really make a difference? Also, how do you feel about those automatic cart cleaners waterbear? I have seen good reviews on them here on the forum. Are they worth the 130.00 they cost? Also, I am curious as to how often I should be cleaning my cart? I was doing it every two weeks and was told that it was too often as it would lose some efficiency if cleaned too often. How do you feel about this? Thanks in advance.
I live in South Florida. I have owned my first pool for 6 years now. 12,200 gal. with exposed aggregate finish, spa with spill over, cartridge filter, pop up bottom cleaning jets, Chlorine by swg. I am eternally grateful for The Pool Forum!!
15'x30' Rectangle w/ ovals at ends 12.2K gal IG pool; Bleach now as SWCG died.; Hayward 1200 cartridge filter; Emerson 2HP pump; 6hrs; Taylor K-2006 La Motte Borate Test Strips; utility; summer: ; winter: ; iPad; PF:9.8
