Thread: pool startup lots of iron
    Holly Springs, NC
    Default pool startup lots of iron
    We just filled our 18x4 round above ground pool (7200 gal. water) with well water. We knew we had an iron problem and immediately put in 21 oz of Simplicity Metal out per instructions. We did this at 6pm on Friday. At 9am Sat. we put the rest of the 1qt bottle in because we saw no difference. We went and had the water checked here are our numbers.
    0ppm - for free, total, and combined chlorine (we have added nothing yet)
    7.1 - pH
    40 ppm - Hardness
    47 ppm - Alkalinity
    10 ppm - Cyanuric Acid
    .03 ppm - copper
    1.88 ppm - iron
    Total Dissolved Solids not run
    0.00 - Nitrate
    Because the iron was so high we added a qt of Jack's blue magic at 12 pm Sat. and let it sit. This morning it still looks the same. We have added nothing but the metal outs and are more concerned with getting the metals out fast at this point then adding chlorine before the algae starts.
    What would be the best stuff to get the iron out? I really wish we could find the Regal Metal Out again, it worked great with our previous pool!
    Thanks,
    Alicia
    Default Re: pool startup lots of iron
    I am not the metals expert, Marie (mbar) is, and hopefully she'll be along soon to look at this thread. However.....the metal sequestrant that you're adding doesn't actually remove the metals from the water, it just keeps them suspended so they don't fall out of solution and stain your liner. You say that you don't see any difference in the pool--are you looking at test numbers or at the actual water? What does your water look like? With the metal sequestrant in, you should be able to go ahead and add chlorine at low levels with no problems until you get more definitive answers from Marie. Or you can add 60% polyquat, which will help prevent the algae in the absence of high chlorine levels.
