Thread: Filter Problems?
    St. Louis, MO, USA.
    Default Filter Problems?
    Here is what is happening. Whenever we vacuum the pool the return line (the one going back to the pool) almost stops flowing after about 3 minutes of vacuuming. We then backwash and rinse and the flow returns to normal.
    We have had the pool for about 5-7 yrs. Do we need to change the sand? If so, can I take off the valve assembly while the hoses are still attached and water in the pool?
    Please help!
    THANKS!
    Lloyd
    Honesdale PA
    Default Re: Filter Problems?
    Sounds exactly like what I have seen on both my system and a friends when trying to vacuum a dirty pool. In my cases dust and probably pollen that settled on the bottom. There was another similar thread recently and what I recommended there was to use skimmer socks to catch most of the crud before it gets to the filter. You will be surprised what they can catch, I was. A pain swapping and washing them so often but beats wasting water on a backwash. Your sand is probably perfectly good and doing it's job.
