Opening numbers, pool cloudy, need help.
Here are my readings after opening:
FC: 7.5
CC: .5
TC: 5-10
pH: 7.5
Alk: 115
CH: N/A (Vinyl)
CYA: N/A
18 x 36 IG vinyl pool
The water is blue but still cloudy.
I am using the PS233 testkit but ran out of the CYA reagent so I cannot test it. I think it is at around 15, I have some pucks in and am trying to up the CYA level.
What are the thoughts on these numbers? I realize that my CC is .5 but for some reason the pool is still cloudy (has been for about a week), I cannot understand why. I have kept the filter running 24/7, run the Dolphin, and brushed. Anything obvious as to why the water is not crystal yet?
Thanks...
Reason: Pool dimensions
Re: Opening numbers, pool cloudy, need help.
First thing: take your water to a pool store and get it tested. You can re-order r-0013 from Leslies on-line or TaylorTechnologies. Buy a BIG bottle to use and store.
Raise your FC to shock level. Since you don't know your CYA, aim for 12-15ppm. Start witha gallon and a half of either regular or ultra bleach and see where that gets you. Plan on holding your FC up there for 48 hours and see if that fixes your problem.
That's just my firstline suggestion.
