Results 1 to 8 of 8
Thread: New sand or add DE?
    White Plains, NY
    Default New sand or add DE?
    Last year I had a real tough time opening the pool (25Kgal ig vinyl). It eventually turned crystal clear but took 3 weeks. This year the same. the #s are 30 ppm TC, 7.2 PH and about 60 CYA. I'm stumped, the water is a light shade of green for 3 weeks now. I keep brushing and vacuuming. So I bring a sample to Leslies and the guy says I must need to change the sand (I've had the pool 5 yrs, never changed the sand, don't know about previous owners). Should I change it or add some DE as I've seen on some threads?
    Default Re: New sand or add DE?
    Try the DE first, but that is helpful for the filtering aspect, but if you still have green water, it sounds like the algae isn't dead. Which makes me wonder if perhaps it isn't algae. Wondering if you fill from a well and it could be a metal problem? Also, how many times a day are you testing and dosing with chlorine? If you are shocking it and then letting it fall and then shocking and letting it fall, it will take longer. You need to sustain the high reading by testing at least twice a day and 3 times a day is even better if you can do it. 30 ppm cl is pretty high for a vinyl pool with cya of 60.
    White Plains, NY
    I've been working on the pool every night (I'm at work all day, so I haven't been able to do it more often). It's municipal water so I'm going to try the DE, I'll let you know how it goes. Thanks.
    White Plains, NY
    Question Re: New sand or add DE?
    My chlorine level has been so high I can't tell (it's been over 30ppm for the past week, with no CC, the guy at leslies confirmed). Once I got the PH level to 7.3 I kept adding bleach. Brush and vacuum daily, scratch my head in the morning. Same happened last year, but one day it just cleared up. I'm really hoping it's the sand. Another question: if the DE doesn't work and i decide to change the sand, how do I remove the top (I have a Hayward S240, i'm not sure if I unscrew the black cap on top, pry it off, or unbolt the rib around the middle)?
    Honesdale PA
    Looks like you would unbolt the middle. All the info is on their website at
    http://www.haywardnet.com
    including manuals, parts lists, etc.
    You don't pry anything.
    White Plains, NY
    Thanks, I found all the info I need. I'll let you know how it works out.
    faithfulfrank is offline ** No working email address ** faithfulfrank 0
    western New York & Leesburg, Fl.
    nyjobz,
    FWIW, I have a 30' round pool with a 150lb sand filter. I too am in NY. Around here you have some guys saying that you should never need to change your sand, while others say you should do it every year.
    My pool is around 5-6 years old. I decided to change the sand this year. The sand looked perfect for about 3/4's of the way down. Then, just under the little pipes, it was all dark, yucky, mud-like silt.
    So, that tells me that it is a good idea, every few years at least to change the sand. My filter works well now.......it did before, but I have to believe it is better now.
    Getting the "old" sand out is easier when you use a shop vac. Make sure you use the plastic sand filler thing to keep the center pipe "on center" when you refill.
    Frank D.
  1. replaced sand and now sand is entering pool
    By flomenhoft in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 01:29 PM
  2. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  4. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
