Re: Aquabot Gets Stuck on Ladder
No, but I have a similar problem with my Blue Diamond (the ONE problem I didn't have with my Dolphin). My B/D gets stuck under the ladder. My ladder is like an I/G's even though it's an A/G because of the deck around it.
My solution is to remove the ladder. I leave a cheap, stamped wrench clipped under the back side of the rail, then I use to loosen the ladder (only 2 bolts) and lift it out and put it over the railing until the B/D is done.
