Re: Thermal decomposition of stored bleach
Our water district uses CC instead of FC so you might want to check that as it will throw off the measurement. According to my brother in-law who works at the regional water district, quite a few plants do this. So you might want to use distilled water instead of tap water or pre-shock the tap water and let the chlorine drop a bit before the test.
