Results 1 to 10 of 25
Thread: Hope you're there Marie ??
    stma is offline Registered+ Thread Analyst stma 0
    Poconos, PA
    Default Re: Hope you're there Marie ??
    Wow...this is a delicate dance between FC and green !!!...As of this morning, Water is finally holding FC overnite, but the metals fell out again...The ONLY thing I did different was to shut down the filter last nite.....Does pool water with metal issues need to be pumped 24/7 ?? I turned the pump back on and i'll see if the stains dissipate
    Numbers:
    FC: 3
    CC: 0
    PH: 7.2
    Alk: 90
    CYA:30
    temp: 81
    Skillset Guest
    I am having similar issues with metals. My FG pool was stained upon opening and I used the Ascorbic acid treatment (followed by Metal Magic) which removed every sigle stain. But, when Cl was raised accidentally, stains came back w/a vengeance and 60% of the pool was covered! Used Metal Magic again, which unbelievably cleared the entire pool. I was impressed. But, stains started forming again just 3 days later, despite a lower cl and lower ph. I'm scratching my head.
    I'm in the process now of figuring out what works. Marie and Waterbear suggested some Calcium in the pool, which I did. Marie was also using Metal Out from Waterwarehouse, which I bought.
    I've been using Extra Strength Metal Out for a few days now and it has not removed the stains - it lightened some stains but did not remove them. So, for the stains that I have, I think the Metal Magic works better. I'm out of the stuff right now and have ordered more this week. Pool is stained right now - I'd say 20%.
    I also had some stain problems last year, but not as bad as this. I probaly used about 3-4 quarts of Metal Magic all season. Again, the Metal Magic is clearing the pool - but I don't want to be burning through a quart of this stuff every week! My CYA was 30 and I am in process of bringing it up to 50. The CYA level is is the only difference really from how I kept the pool last year.
    I'd love to be able to have a stain-free pool and use a weekly maintenance dose, but I really find I have to use a lot of product to get rid of the stains.
    Perhaps running at a higher CYA and a higher Cl, it will help. My ph is pretty consistent at 7.2. I know higher Cl has been stated to bring stains out, but perhaps with CYA, maybe less so. I only say this from my experience last year.
    mbar's Avatar
    Ashland, PA
    I know how frustrating it is A couple of seasons ago, I kept the stain dance going. Last year I hardly had any stains. This year I had a lot of stains at the beginning, but now I haven't had any bad ones since putting in some ascorbic acid. I do find that using pucks or calhypo seem to add to stains. I have my cya at around 60 now. I am still not sure why sometimes the sequestering agent works, and sometimes the stains keep coming back no matter how much is in there. Every time I see some stain start, I take my ph back down, add some sequestering agent and they go away. I try to keep my chlorine at the level of the best guess chart. It is a balancing act, and sometimes the stains don't come off with the sequestering agent. I then just add some ascorbic acid around the perimeter of the pool and they disappear without taking the water out of balance (just lowers the ph a bit). I do keep my filter running 24/7, I think it may help with staining, but not much. I wish I could be of more help, but it is just not an exact science. I will keep trying to find out what works, and if everyone with stains posts what works for them we can learn from each other.
    Northeast PA
    Poconos, PA
    As the day wore on (cloudy but warm), the CL dissipated as expected ALONG WITH the green tint !!!...once the green disappeared, I check the CL which read 1.5-2...
    just dumped a qt of 6% which should raise it to just above 4ppm...i'll see what happens...
    szampino is offline Registered+ Thread Analyst szampino 0
    How is it going?
    When you get a chance post an update.
    Please include full water make up,fc,cc,tc,alk,ph,cal,cya. Please also include your Pool size, liner, and filter type.
    Revived POP
    Intex Blow-up Ring 18x48 round
    Cartridge Filter
    mbar's Avatar
    Ashland, PA
    Yes, I would be interested to see if the stain came back with the additional chlorine. It is how we all learn It is always good to post a current set of numbers
    Northeast PA
    Poconos, PA
    Perhaps because it's Father's Day, things are looking up for me...Got POUNDED with rain last nite (sure you saw the same Marie), and thought i'd wake to a nitemare...Fortunately the CL held it's own over-nite...The same 5ppm yesterday was the same 5ppm this AM...Sun is on the pool now, so I'll see how much I lose through the course of the day...Water never "tinted" green after the Clorine addition, so maybe I'll be OK.....Rain DID raise the PH to 7.8 though...
    as for the specs:
    18 ft round/ sand/ vinyl/ 7600 gallons
    FC: 5
    CC: 0
    TC: 5
    PH: 7.8 (acid added minutes ago)
    ALK: 90-95
    CYA: 30-35
    CAL; 130
    taking your cue, It's just ONE THING at a time for me !!....have not had the need to use additional metal out as the water appears to "clean-up" on its own after clorine additions...... However. my days of 'hard" shocking may be at an end...anytime more than 2 qt. of bleach is added, the water tints green....(In the past, I never thought twice about dumping 2 gallons at a time to "clear" things up).
    So far, so good.....Thanks for asking....
