Thread: What is the best Calcite Saturation Index (CSI) for a saltwater pool
    Dec 2005
    Honolulu, Hawaii.
    Default Re: What is the best Calcite Saturation Index (CSI) for a saltwater pool
    Thank you both for your replies.
    The pool is saltwater set at 3000 ppm and is controlled by a Pool Pilot Auto Digital Controller. Setting the ph at 7.5 allows it, under normal circumstances, to never exceed 7.5.
    As the pool never gets colder than 78 F in the winter and never hotter than 88 F in the summer it seems the following parameters would be best according to the "Pool Equations" spreadsheet. This way no parameter would need to be changed.
    Measured pH 7.5 7.55
    Total Alkalinity (ppm CaCO3) 70 70
    Free Chlorine (ppm Cl2) 5 5
    Cyanuric Acid (ppm CYA) 35 35
    Calcium Hardness (ppm CaCO3) 450 450
    Total Dissolved Solids (ppm) 4,000 4,000
    Total Sulfate (ppm SO42-) 0 0
    Total Borate (ppm Boron) 50 50
    U.S. Gallons 10,000 10,000
    Temperature (F) 78 88
    Total Chloride (ppm NaCl) 3585 3588.1
    Carbonate Alkalinity (ppm CaCO3) 52.5 50.3
    Langelier Saturation Index (LSI) -0.16 -0.03
    % HOCl (vs. Total Free Chlorine) 1.30% 1.20%
    OCl- (as ppm Cl2) 0.074 0.093
    HOCl (as ppm Cl2) 0.064 0.062
    Calcite Saturation Level (CSL) 0.51 0.66
    Calcite Saturation Index (CSI) -0.29 -0.18
    I wouldn't worry about the winter since the colder water temperature will naturally have the pH move upward, all else equal (so let the pH drift up on its own to 7.6 or so during the winter). As for the summer numbers, the roughly -0.2 saturation index is fine since you don't want scaling in the salt cell where one plate is at high pH. Since you are using borates and keeping a lower TA to avoid the rate of pH rise (I assume), you have a higher than average CH to compensate. This all looks good.
    Richard
    Dec 2005
    Honolulu, Hawaii.
    chem geek,
    Thank you for your very quick reply. Yes the 70 setting is so we do not have to compensate for pH too often. The 7.5 pH we try to achieve to offset Hawaii's Volcanic Dust, aka Brown Dirt (Ferric Oxide or Iron Rust), which blows in at 16 mph to 26 mph. At higher pH(s), as you know, it goes out of solution and stains the pool brown.
    One quick quetion should I use a CYA adjustment for Alk or is it in your spreadsheet?
