Thread: Sentry UV and pH Stabilizer
    Default Sentry UV and pH Stabilizer
    Is anyone familiar with the pH stabilizer product associated with Sentry UV? [http://www.sentryuv.com/products.htm]
    Default
    Never heard of the product, and the link doesn't work......
    Default
    The BEST and cheapest way to stabilize pH is to have the correct Total Alkalinity level. You raise T/A by adding ordinary baking soda. You lower it via a procedure that involves adding acid and aerating your water. Sooner or later the procedure will be spelled out in detail on this new board.
