Results 1 to 10 of 12
Thread: Liner Problem
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Liner Problem
    I opened my pool today and found that I had lost about a foot of water. What really concerns me, and Im not really sure how to describe it, is some scaling Im seeing on my liner. Its only in a few places and well above where my water line has ever been. If I scrub it starts to come off and the liner appears a briter blue than the rest behind it. The liner does not appear damaged behing the scaling,but you never know. Here are some pics, Id really apprecieate any help here.
    John
    24ft Round, Vinyl liner
    Default Re: Liner Problem
    I'd be giving nothing but a WAG, so I'll have to let the more experienced pros tackle this. But it looks like whatever stuck to the pool bleached it--which shouldn't be a calcium function, I don't think.
    Does the liner feel any different there--softer, weaker, thinner? Have you tried rubbing it with Vitamin C, or a weak bleach solution? I'd try that, even using a Borax or Baking soda solution--the WORST is that your liner needs to be replaced anyway. The best is you get it back to true color. The intermediate is the liner is OK but ugly.
    The only thing I've tried so far is rubbing it with the pool water and a dish towel. It doest feel any thinner than the rest of the liner, just looks a lot cleaner. Not really any softer either.I only have it in 3 or 4 places and all are by where my top posts are.
    When I rub it, it comes off kind of like when rubbing a price tag off something - in little pieces that are blue. Im hoping its not a layer of the liner. I just dont know how it could be so high and only in those spots.
    Im going to the local pool store now to get some cleaner for my scum ring and hopefully that will take care of it.
    John
    Sorry, what is the vitamin C method?
    John
    Cool Re: Liner Problem
    John, from what you and Carl said, I'm thinking that the screws that hold the top rail down are oxidizing and what you are seeing is rust that has dribbled down the wall. The ascorbic acid (vit C) will liberate the stain, Mr. Clean Magic Eraser also has been known to work. I'm not a large fan of the pool store tile line cleaners - I just use a paste made out of baking soda on a green kitchen 'scrubbie' to remove the oils and dirt that accumulate at the water line (though sometimes a weak acid solution is needed)
    I sincerely hope that this is helpful to you and that you get to enjoy the pool more than you have to work on it (in CT - we are starting a 4 day heatwave with temps over 90 - maybe now the condo association will let me put in a pool )
    Well heres what I've tried so far:
    Magic erase alone - had no effect
    PH Decreaser - no effect
    Proteam Vinyl Cleaner - no effect.
    I gonna try the vitamin C and paste mixture tomorrow. Its been warm her in ohio, we hit 92 yesterday. 88 today and high 80's tomorrow. The pool water is only 62 though. I just put the solar cover on today.
    John
  1. New Liner Problem
    By Angelo in forum In-Ground Pool Construction and Repair
    Last Post: 06-27-2011, 11:24 PM
  2. Is this a problem? New Liner?
    By pq1747 in forum In-Ground Pool Construction and Repair
    Last Post: 06-10-2011, 10:27 PM
  3. New pool liner problem
    By janmo in forum In-Ground Pool Construction and Repair
    Last Post: 09-12-2008, 11:47 PM
  4. Liner problem
    By Donna's Poolboy in forum Pool Equipment & Operations
    Last Post: 08-15-2006, 05:19 PM
  5. Minor liner problem
    By topnotch in forum In-Ground Pool Construction and Repair
    Last Post: 08-03-2006, 09:37 PM
