I did the panty hose thing around the skimmer but the whitish sediment is going right through. I see it coming out my returns when I vacuum. I feel helpless. I thing I am taking a trip to the pool store........![]()
How high was your calcium when you added the sequesterant? Is it the same reading now or has it dropped?
here are my numbers:
CYA=39
tot chlrine=0.4
free chlorine=0
ph=7.7
tot alk=83
tot hardness=292
Have you attempted vacuuming to waste ?
Marie (mbar) I believe is on vacation...she would probably let you know if the sediment is a residual from the ascorbic powder...
You might want to read through my 2006 post, sounds like you're having the same issue that I did.
http://www.poolforum.com/pf2/showthread.php?t=4348
Revived POP
Intex Blow-up Ring 18x48 round
Cartridge Filter
Yes, it is from the saturation of the water that it gets cloudy, it precipitates calcium and some other stuff in the water that the water can't hold anymore. You probably had some of your calcium and alkalinity fall out, if you compare former chemistry you had. It can take time for it to dissipate. You can put a coffee filter in your basket of the skimmer to catch some of the really fine particles. You can also use a floc, if it really bothers you - follow the directions on the bottle, then vacuum to waste. You can swim - it is only cloudy from too much saturation, it is clean water!
Sorry I didn't answer, Finally got on the computer! The vacation is great!
Northeast PA
I did use PowerFloc by Biogaurd. After vacuuming a lot of water and refilling, I must say that it looks pretty good. It is still cloudy but very much better. My kids were in the pool today.
The stains have not returned, and it has been 7 days since I started the Vit C treatment. I also got a good kit K-2006 and here are my numbers:
FC=2ppm
CC=3.5
ph=7.0 (added 4# sod carb to bring to 7.4)
alk=100
CH=340
CYA: did not test because water is still cloudy.
My questions are:
When can I Super Chlorinate to rid the CC?
When will the cloudy water become brilliant.
Can I still use Calcium hypochlorite. I have been using straight bleach lately but I find the granular easier to use and takes less space. Also to superchlorinate would require 5 gallons in my 15k ig vinyl pool. I just want to be careful of not increasing my CH.
Thanks for all the help. I am seeing the light at the end of the tunnel.
