I woke up the other morning and my hot tub was empty. I tried to figure out what was up and this is what I have come up with. When I turn the pump on I am only getting about half the pressure that I should have. On top of that my hot tub drains.
I can fill the hot tub, turn on fill for the hot tub and it will maintain the water in the hot tub but won't flow over into the pool. Also, when I do this the filter baskets don't seem to have much/any suction.
I have an automated pool with 2 CVA Valve actuators. Is there a way to manually turn these valves as I am guessing that this is the problem. There is a switch that has 3 positions on the valve and it does not move when I change the position. This is the actuator that is on the line coming into the pump basket prior to the filter.
Help, I am clueless and have no idea what to do. It's getting hot here and I need some circulation quickly.
thanks,
