Thread: Sta-Rite Pump / A. O. Smith motor stopped
    mas985's Avatar
    Pleasanton, CA
    Default Re: Sta-Rite Pump / A. O. Smith motor stopped
    Sounds like a capacitor start/capacitor run (CSCR) motor. These are a bit more efficient than the capacity start/induction run (CSIR) motors. The capacitors are usually the culprit for motor failures and the likely cause of your problem as well. I would try replacing one or even both of the capacitors as it is an easy and inexpensive fix.
    Mark
    Long Grove, Illinois
    Smile Re: Sta-Rite Pump / A. O. Smith motor stopped
    You're right. It was the "run" capacitor. I was able to track down the specs at A.O. Smith (motor manufacturer) and find an equivalent "run" capacitor (same volts, MFD, and physical size to fit under cover) at Grainger for $9.52. Had to add clips and some wire ... but all is good. The pump started right up. It seems to be running quieter as well.
    Fiberglass IG with hot tub/18,500 gallons
  1. Replacing the rotating swich on AO Smith Motor
    By hotajax in forum Pool Equipment & Operations
    Last Post: 06-08-2013, 10:11 AM
  2. Wiring a 2 speed A.O. Smith pump motor
    By wack70 in forum Pool Equipment & Operations
    Last Post: 08-26-2011, 12:47 PM
  3. Sta-Rite 3/4hp pump not working. Replace motor only?
    By Cinda in forum Pool Equipment & Operations
    Last Post: 06-11-2010, 02:01 PM
  4. Bearing Replacement 1hp AO Smith Motor
    By Spurgeon in forum Pool Equipment & Operations
    Last Post: 05-15-2010, 02:18 AM
  5. AO Smith replacement motor suddenly noisy
    By rbonin in forum Pool Equipment & Operations
    Last Post: 05-31-2009, 01:00 PM
