You're right. It was the "run" capacitor. I was able to track down the specs at A.O. Smith (motor manufacturer) and find an equivalent "run" capacitor (same volts, MFD, and physical size to fit under cover) at Grainger for $9.52. Had to add clips and some wire ... but all is good. The pump started right up. It seems to be running quieter as well.
