Results 1 to 10 of 12
Thread: I have never had this much trouble before!
    Western Pennsylvania
    Unhappy I have never had this much trouble before!
    Got everything cleaned out of the pool, been vacuuming. My chlorine is at shock level, my alk is 200 and my ph is 8.0. What do I do now? My pool is a very very light shade of green. Been filtering 24/7 since the 6th and I cannot get it clear. Can someone please help me? I got three very anxious and impatient children waiting to swim. Ty.
    Default Re: I have never had this much trouble before!
    I even changed out my sand, thinking after 6 years it was worn out. I did that yesterday.
    CYA is 30, which is good I reckon.
    If you could post a full set of test results and some info on your pool it would make things easier to try and help you. Telling us your chlorine is a 'shock level' is really pretty meaningless.
    TC 5.6
    FC 5.3
    TA 200
    CA 190
    pH 8.0
    Thanks, I feel pretty meaningless lately too dealing with this pool.
    Quote Originally Posted by seminolewind View Post
    TC 5.6
    FC 5.3
    TA 200
    CA 190
    pH 8.0
    "shock level" for CYA=30 is between 10 and 15, not 5.3. See the "Best Guess table"
    Your pH is too high. Get it down to the mid 7's before you add chlorine, THEN shock it to 10+ and keep it there. pH of 8 makes it very hard for your chlorine to work.
  1. Is it just me? Or does anyone else have trouble?
    By keschete in forum In-Ground Pool Construction and Repair
    Last Post: 07-13-2011, 09:16 AM
  2. pump trouble
    By mohawk in forum Pool Equipment & Operations
    Last Post: 11-21-2009, 09:59 PM
  3. Trouble getting CC to zero.
    By huskerfan in forum Dealing with Algae & Slime
    Last Post: 05-11-2007, 05:09 PM
  4. How do I add CYA? Having trouble...
    By Aviendha in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-12-2006, 04:25 PM
