Hiya all.... First, this is a combo question.... so I hope this is the proper forum...
I have been here before when I had my ''kiddie" pool and found the help here great!!
Now I finally took the plunge.... and got an real BIG people pool...
First what I have.
10x18 AquaSport 52" 5000gal
Hayward c400 Cartridge Filter
Aqua-Pro 600 heat pump
Goldline Aquatrol RJ SWG
Questions :
What test kits should I get and what tests should I be most concerned about??
What besides salt… what other chemicals should I have on hand?
Any tips or suggestions on settings / controlling the SWG?
Any do/don’ts that I need to know???
If you have any questions about your AquaTrol, I've recently been certified to work on them by Goldline/Hayward and will help you as needed.
) this weekend.
Depending on a few variables, especially temp, the unit can read +/- 500 ppm - I trust the default most of the time, I use the instant just to check when the main display is 'funky' You should have the pool circulate a couple hours before fully trusting either - and never trust either until 24 hours after adding salt.
