Results 1 to 10 of 18
Thread: algae
    hannadock Guest
    Smile algae
    I opened up my pool memorial day weekend and finally got a clear pool a week later, BUT yesterday I noticed some algae starting to form on the wall. I brushed and vaccum on waste. It has been in the 90's here for a week and a half. My numbers are within spec based on this website recommendations.
    How long should I run my pump?
    How often vaccum the pool?
    How long should I run my kreepy krawly?, I don't use it much at all.
    Do you chlorine tablets hurt? I bought some on sale last year at a good price at Lowes.
    I have a inground vinyl pool 20 X 40 around 36000 gal.
    I had the same problem last year with the algae and my numbers were always in range.
    Sorry for all the questions
    Jul 2006
    Albuquerque, NM, USA
    Default Re: algae
    I run my pump 12 hours per day, when I'm not fighting algae. Since you have algae, leave the pump on all the time. And get the FC level up to shock level.
    I vacuum my pool when I see something that needs picked up. Which usually works out to once per week. I brush more often than that.
    Since I don't have a kreepy krawly, I'll pass on this question.
    Chlorine tablets come in different kinds. The tri-chlor ones with stabilizer will increase your CYA and decrease your pH. Once your CYA gets to 50, I think you should stop using the ones that contain stabilizer. I have seen other tables that contain cal-hypo, and do not contain stabilizer. Those will increase your CH (calicium hardness). I forget what the upper limit is for CH is a vinyl pool, I think it can lead to cloudy water if you go past the upper limit.
    You should post your numbers so that the pool experts here can give you better advice.
    Jim
    10,000 gallon above ground vinyl
    Albuquerque, NM
    Default Re: algae
    Quote Originally Posted by jimk0512 View Post
    Yep. We need to look at numbers to be able to offer advice. Repost with current water testing results from a drops-based kit (not teststrips) and somebody here can help you get your pool cleared.
    hannadock Guest
    Default Re: algae
    ph 7.3
    alk 170
    cya 45
    tc 4.0
    the tablet I bought are by Dupont sanitizer 3" chlorinating tablets
    99% trichloro-s-trizainetrione with available chlorine 90% and 1% other which it doesn't say what it is
    Default Re: algae
    Quote Originally Posted by hannadock View Post
    ph 7.3
    alk 170
    cya 45
    tc 4.0
    The tabs you have are trichlor, which are raising your CYA as we speak. Your CYA is at a point where you already need to keep a minimum of 3 ppm chlorine, and preferably closer to 6. I would definitely stop using them now and switch to bleach as your chlorine source. To clear up your algae, you need to add chlorine to the pool til you get to 15 ppm and keep it there, with your pump running 24/7, until the pool goes to cloudy blue. You'll need to test and add more bleach 2-3 times daily until this happens. When the algae is gone and the water is cloudy blue, then keep your filter running but you can let your chlorine drop back down to the 3-6 ppm range, but NO LOWER than 3.
    Brushing your pool daily during this process will speed it up, and running the vacuum certainly won't hurt.
    hannadock Guest
    Default Re: algae
    thanks I will let you know what happens
    hannadock Guest
    Unhappy Re: algae
    alright. I put more than 10 gallons of bleach in Saturday evening now my level are terrible. Everything look good yesterday.
    chlorine less than 1.3
    ph around 7.7
    alka 200
    cya 35.
    my slide has started to turn yellow from the bleach which it hasn't before. My alka has always been within range but after the rain came up. My ph has risen and looks like my cya has gone down. I have scrubed my walls vacumned on waste. Let my pump run non stop. At present my pool cleaner is running, just turned it on. HELPPPPPPP. I am wasting money
    Is there a difference between the Walmart brand of bleach and Chlorax.
    Default Re: algae
    What are you using to test? Are you using strips or a drop-based test? Keep in mind that test strips are not accurate enough to help correct a problem--they give you a ballpark, but you really need accurate numbers to fix problems. If you don't have a drop-based test, you need to get one.
    Once you have algae growing, you have to maintain a shock level--key word MAINTAIN--until you have killed the algae. With your CYA level, you need to get your chlorine up to 15 ppm and keep it there by testing and adding more chlorine 2-3 times daily until the algae dies. It won't help to shock it once, then let your chlorine come down. 10 gallons of 6% bleach will raise the chlorine in your pool to approximately 16 ppm--but if you haven't add any since then, you're not going to make any progress against the algae, since the chlorine is being used up in the battle against the green stuff.
    Bleach will sometimes cause a temporary rise in pH, and high chlorine levels will often cause the pH test to give falsely high results. If your slide is turning yellow, and you are using test strips to test your water, I strongly recommend that you have the water tested using drop-based testing to make sure you really know what your chlorine level is. If it's not at 15, then you need to get it there and hold it there to kill off the algae.
    WalMart bleach (generic) is 6% sodium hypochlorite (chlorine). Clorox is also 6%, I believe ( you can look at the label to confirm). However, clorox has started adding another ingredient to the bleach that is designed to help lift stains, but can appear in pool water as a white sediment on the bottom. WalMart bleach is cheaper and has no added ingredients (as long as you stay with the plain ultra bleach and make sure you're not buying the stuff with the scents added--you don't want that).
    hannadock Guest
    Red face Re: algae
    I am using the drop based testing kit. I have 3 different ones and use all 3 when my results are bad just to see. All 3 gave the same results. Should I be concerned about my CYA. thanks
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Wanted: Mustard algae or suspected mustard algae
    By gonefishin in forum Dealing with Algae & Slime
    Last Post: 08-30-2007, 09:40 PM
  4. Green algae? Mustard algae?
    By AE340B in forum Dealing with Algae & Slime
    Last Post: 07-15-2007, 09:32 PM
