This is my ticket for Heaven (when all's working..) :
22k Gal gunite IGP
38 SF DE filter, 1 HP Hayward Super Pump
Raypak 350k BTU Natural Gas Heater and solar cover
8 gal Liquidator with bleach
Dolphin robotic cleaner
Taylor k-2006 test kit
Basically, yes. Copper will corrode (oxidize) becoming copper ions in water that can eventually stain. How fast this occurs depends on a variety of factors. The pH is most important with low pH rapidly increasing corrosion. Higher chlorine levels is another factor with the FC/CYA ratio being most relevant (or FC alone, if CYA is near zero). The conductivity of the water, roughly approximated by TDS or salt level, is another factor.
So a particularly corrosive scenario would be a pool without CYA (such as most indoor pools) with an SWG system (so the water has 3000 ppm salt) operating at a lower pH. Nevertheless, it would be best to avoid the use of pure copper in pools.
Copper pipes in homes have been exposed to chlorine (up to 1 ppm FC) with no CYA and have generally not corroded, but there is little dissolved oxygen in the pipes, there is little conductivity since the TDS is low, and there are some corrosion inhibitors usually added to the water.
Richard
Richard,
Are you saying that public water companies add or may add corrosion inhibitors to their systems or are you referring to the sacrificial elements used in some water heaters?
Public water companies add corrosion inhibitors. When many of them switched to using monochloramine instead of chlorine, they had to switch to use different corrosion inhibitors. Initially there were reports of corrosion after the switch in some communities until they sorted this all out.
The sacrificial anode in water heaters is separate and is there primarily to protect the water tank (which is usually glass lined, but there are voids where this is exposure to steel), not so much for the copper.
Richard
Then I need to work with a PVC pipe, but its OD is about 1/32" too wide. What's the best way to decrease its OD other than filing or sanding it down? I'm talking about no more than 4" to 6" long pipe.
22k Gal gunite IGP
WaterMan....Never tried to reduce the diameter of PVC pipe, only expand a little, but PVC will get pretty soft in boiling water. Off the wall but maybe you can figure some way to extrude it through some kind of die when it is soft.
Richard....just what we need in drinking water. Another possible carcinogen. Any idea what these inhibitors are? I'll stick to my well.
The corrosion inhibitors vary but are usually phosphates or silicates and they also adjust pH and the level of carbonates (mostly for buffering). For example, when fluoride is added to drinking water, it is often in the form of fluorosilicates with the silicate portion being a corrosion inhibitor. The amount of these substances is small and does not have evidence of causing cancer. Believe me, the people analyzing water systems are pretty particular about what they put in which is why they use multiple steps of sanitation to minimize chlorine disinfection by-products.
It's also relatively simple to use a decent charcoal-based water filter to eliminate the chlorine or monochloramine as well as other substances from the water. We use one at home, mostly because my wife can't stand the taste of the water otherwise (she's got very sensitive taste). Personally, I don't like the taste of water even if it's distilled (which has no taste), but then I'm weird.
Richard
22k Gal gunite IGP
Someone mention single maly scotch?
I'm partial to 17yr old Glenlivet. smooooth.
Copper has been used in commercial pools for YEARS, but as mentioned, not common these days.
You may try researching Pasco Ram Bit. A little expensive but can do what you're looking to do.
Sean Assam
e-mail: [email protected] --- www.autopilot.com - www.aquacal.com
