Re: Cloudy Water
It sounds like you are battling an algae bloom. It wasn't there long enough to turn the water green, and you got enough chlorine in there to stop it from getting worse. However, the fact that the chlorine is not holding means that it is getting used up fighting something. I suggest you take the chlorine level up to shock, and hold it there until it holds overnight, testing the water as often as possible to bring it back up to shock. The more consistent you are, the faster the water will clear.
Northeast PA
16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
