Re: air in pump, pressure/vacuum problems??
After thinking about this a bit, I am convinced I have a sucking air problem somewhere. I do hear a gurgling/sucking noise just under the skimmer basket, (I JUST found).
Also, I hear a gurgling, air trapped, "jumping pebbles" sound in the multiport valve, like trapped air. Looking through the clear top where the pump basket is, there is always not a bunch of swirling bubbles on the top that are trapped in the dome of the top.
None of this was like this in past years. Ironically, I was more careful this year with connections, replacing teflon tape, etc.
I will replace the vacuum hose, and recheck ALL connections until I solve this thing.
The pump basket drain is ok, and I'm pretty sure the o rings are ok and the pump basket clear lid is good and tight and the o-ring lubed. I'm thinking the air leak is just under the skimmer basket, or a pinhole in the vacuum hose.....
I just do not know why the problem is much more evident when vacuuming, and hardly there when skimming.....unless it IS the vacuum hose......
I'll solve this thing even if I have to JB Weld everything...!
Frank D.
