Re: Chlorine Lock ????
Borates are a rather weak algaecide. They do inhibit algae growth a little, but if the chlorine demand in this particular case is due to algae, I doubt the borates will help enough to make a difference. If this is truly nascent algae growth, then a costly but effective way to stop it is with a phosphate remover, but that's a last resort (a copper algaecide would also work, but then you've got copper to deal with).
The nature of this problem, with FC rapidly consumed, CC rising and then dropping (even at night and rather quickly), sounds very much like ammonia. I went through the posts in this thread and it sounds like anhydrous ammonia was possibly added to the pool. This was a pool opened upon startup which is typically when an ammonia problem can occur after soil bacteria convert CYA into ammonia. I did not find an earlier post with an ammonia measurement -- only yesterday's post that said it was tested for ammonia and was negative. I wouldn't trust the pool store numbers at all.
poolrescue30, if you still have your own ammonia test, test the water again for ammonia. If you do not have such a test, please get one at a pet/fish/aquarium store. The ammonia test is inexpensive. Do not trust the pool store for measurements. The rapid drop in TA from 160 to 16 in 10 days and then to zero three days later makes no sense whatsoever (a zero TA in the normal TA drop-test showing up immediately red instead of green would mean the pH is 4.5 and is completely inconsistent with the reported pH of 7.1).
Richard
