Re: Chlorine Lock ????
poolrescue30
Ok,
I'm going to shock today with 8 gallons of the Walmart Ultra bleach.Do I pour it around the pool or into the skimmers? I have a vinyl liner and don't want to bleach it .How will I know if I hit 20ppm ??
By testing your water. You DO have a good testkit with the FAS-DPD chlorine test, don't you? It's a BASIC piece of pool equipment!
When should I add more bleach to "keep it" at 20ppm ??
When your testing has shown that the level has dropped below 20 ppm.
Hope this helps. You really need a good test kit, Many people don't get one until they run into a problem like yours. If you has been testing your own water all along... you get the idea.
