Re: Chlorine Lock ????
Update:
the pool is still a little cloudy from all the Calcium Hypo that I put in over the weekend.This morning I put in a gallon of 6% bleach .I just tested it with a FAS-DPD test kit.I did it twice , filled it till the 25ml mark, and it turns a nice pink when i put the powder in, 2 drops (multiplied by .2) turns it clear so that would indicate .40 ppm of FCL and after turning it pink with the R0003 , it only took 1 drop to turn it clear, which would indicate the CC is .2ppm.
Are we winning this long battle ?? Should I pour in 8-10 gallons of 6% bleach to shock it overnight ? or wiat for the chemical company's water test result which should be in in the next couple of days ?? THANKS
