Results 1 to 10 of 18
Thread: No Chlorine. . . If not Algae, then What?
    Default Re: No Chlorine. . . If not Algae, then What?
    The water going from clear green to cloudy green is the real clue to algae. I suggest you abandon all other "corrections" and shock that water up to the shock level of 15 and keep it there. All your other problems are minor once you have an algae infestation.
    That's IMHO.
    mbar's Avatar
    Ashland, PA
    Yes, you should sanitize the pool first before you deal with the metals - the chlorine will get used up with the sequestering agent too. Sometimes sequestering agent makes the water cloudy too, so it is best to know that the water is clean before starting with the metals, this way there is no question that it is not algae. Keep us informed and we can help you through this
    Northeast PA
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    Ok, I shocked the pool at sundown tonight. I did not add more sequestering agent because I had put in more than the instructions called for already, which could be part of my problem, I now realize. The pool liner guy said I needed to get that sequestering agent in right away because we have so much iron. What I should have done was get chlorine in right away, as the pool was filling, it seems. I must learn not to listen to "pool guys"! I'll keep it at shock level now until things clear up. I'll keep you posted and thanks again for all the great help.
    Pam, Illinois
    "17'x33' oval 14.5K gal IG vinyl pool; liquid chlorine; Hayward Pro Series, M-S-244T sand filter; A.O. Smith Centurian, Switchless, 1.40 HP pump; Right now 24/7hrs; Pool Solutions PS234
    Serial #6511, Drops / Powder; Community well; summer: none; winter: mesh; ; PF:8.3"
    The pool guy was correct in saying to get the sequesterant in right away. The purpose of that was to 'deactive' the metals so they would not react witht the chlorine that you should have put in next!
    Central Illinois
    Thank you for the further explanation Evan. I learn more about this pool every summer. By the way, when I said I need to not listen to "pool guys", I was NOT talking about You!
    Last night, it turns out, that my husband and I both added chlorine to the pool which resulted in shocking it to 26! This morning the pool looks basicly the same except that when I got down to get my water sample, I could see a little further down the side. My chlorine reading this morning is:
    FC - 12
    CC - 1
    TC - 13
    Pam, Illinois
    Quote Originally Posted by Pamsel View Post
    FC - 12
    CC - 1
    TC - 13
    OK!!!!! That means you are fighting it and making progress. You should have immediately added bleach to raise the FC back to either shock level or 25, whichever is higher (because you are fighting so much). Check it 2 to 3x a day and add bleach whenever it drops below the shock level.
    Keep that filter going 24/7 and vacuum to waste everyday--and brush it once a day too.
    Central Illinois
    Thanks, Carl. We're on it! I'll let you know when it's clear and sparkling!
    Pam, Illinois
