Test Check
Hi-
I was hoping smarter people than me could comment on my test results. Here they are:
FC: 6
CC: 0
PH: 7.8
TA: 150
CH: 210
CY: 25
My PH always runs high. I'll be lowering it tonight with Muriatic Acid. The TA seems high, should I lower it? Could it cause my PH to always be on the rise?
The last two years I've had recurring mustard algae outbreaks. It's in remission now, but if the chlorine drops to around 1 on a hot day I still see it creep back.
My CYA seems to have dropped by about 15 in the last 2-3 weeks. Is that possible? I'm in SoCal, so I've gone to supplementing bleach with a floater to make sure the chlorine stays up and I'm hoping that will help enough with the CYA.
Are any adjustments in order?
Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
