Re: Test Check
The graphs of chlorine effectiveness vs. pH with and without CYA are in this post. The bottom line is that with CYA in the water, it acts to buffer the disinfecting form of chlorine which means the disinfection rate doesn't change that much with pH. Without CYA, going from a pH of 7.5 to 8.0 drops the chlorine effectiveness by around 50% while with CYA it only drops around 15% Of course, without CYA, the chlorine effectiveness is huge so even a drop of 50% isn't a big deal (it's still over a factor of 15 higher at the same FC level when the CYA is 30 ppm).
There is a theoretical increase in the breakdown of chlorine from sunlight at higher pH since hypochlorite ion breaks down about 6 times faster than hypochlorous acid from the UV in sunlight. Though the disinfecting chlorine (hypochlorous acid) doesn't drop much at higher pH, the hypochlorite ion increases a lot to compensate. With an FC of 3.5 and a CYA of 30 ppm, going from a pH of 7.5 to 8.0, the rate of chlorine loss from sunlight is almost tripled. However, we've never done any experiments with real pools to see if this "theory" actually happens in practice. There have been a couple of anecdotal reports indicating that some effect of this sort does occur. Just remember that chlorine loss has multiple sources and we're only talking about the loss due to sunlight in this discussion.
Richard
- You may not post replies
- You may not edit your posts
Forum Rules
