Results 1 to 10 of 11
Thread: Test Check
    Carlsbad, CA
    Default Re: Test Check
    Thanks! I have a 25k gunnite pool. I've always shocked with liquid chlorine, never even tried cal-hypo. Our source water my be high in both TA and pH. Maybe I should test that to get a baseline?
    However, I don't like pH at 7.8
    I don't either, but it's always a struggle keeping it down. I'm dropping it tonight to 7.0 - 7.2 but in a few days I'm sure it will raise back up. It threw me for a loop when Home Depot cut the strength of acid in half without any clue.
    Falling CYA is due to dilution unless you have a NASTY algae bloom.
    Maybe that's it. I did have to deal with algae when I found my CYA so low (then I raised it to 40) and the sun so hot that chlorine wouldn't last even for a day. Do you think the floater technique will work to keep it in check and raise the CYA?
    Thanks!
    Quote Originally Posted by jhm View Post
    Thanks!
    Checking your fill water is always an excellent idea--ours used to have a t/a of 180.
    Lowering T/A is done indirectly. T/A is linked to pH. Not only is it a pH buffer, but as pH rises and falls, T/A rises and falls with it. So....you have to lower the T/A relative to the pH. The way to do this is to lower the pH and bring the T/A down with it.
    Then there has to be a way to raise pH without T/A going up again--Borax won't do it, Soda Ash won't do. The trick is aeration.
    Aeration sounds fancy but it's not. Leaving your pool uncovered will cause some aeration and pH increase, but lots of splashing kids or a fountain causes it to increase the pH much faster. You can point the return jet at the surface too, that helps. I won't go into the chemistry of the gassing off--in part because I only partially understand it myself.
    When pH rises from aeration, you then add acid again to lower it back to 7.0, each time measuring your T/A after you aerate it back up. When the T/A is where you want, it you stop aerating. It's a racheting process.
    Since you are having troubles keeping pH down, you could try getting the T/A down to the 80-100 range--100 max--and see if that helps stabilize it. Don't start using Cal-Hypo, but stick with liquid bleach/chlorine...I thought with your CH # you might be since pH was rising to.
    If you want to raise your CYA and are fighting rising pH, then Tri-Chlor pucks are an excellent way to do it. Be sure to check CYA every week though and stop using them when you hit your CYA target.
    aylad, my fellow mod down in Louisiana, likes to run a much higher CYA than we Northernors, Poconos and myself, do. That's because she faces far more intense sun and heat on a regular basis and it's just easier and cheaper to run the pool with a CYA of 70 or 80 and maintain a residual FC level of 5 to 10 ppm. She actually uses less chlorine that way.
    Your K2006-C is really not any different than the older PS-232 and PS-233 kits sold by PoolSolutions--just organized a little differently--and you have the acid and base demand tests as well. It's all Taylor reagents anyway.
    Hope this all helps.
    A few things that will help iwth the pH....
    First lower your TA to around 70-90 ppm. Once this is accomplished bump your CH up to about 300 ppm. (The reason this needs to be done is complicated so I am not going to give the full explanation here but it's basically because you have a plaster pool).
    Second, once your TA is in line keep your pH at 7.6 and not lower. The lower you put the pH the faster it will rise (we use this fact to our advantage when we lower TA). When you pH rises to 7.8 use the acid demand test in the K-2006 to bring it back down to 7.6 and not lower.
    Finally, adding borates to 50 ppm to your pool can help with pH stability tremendously. If you decide to add borates there is a very good tutoarial on how to do so here.
    Carlsbad, CA
    Thanks for all the advice. It sounds like I need to work on the TA by lowering pH to around 7.0 for a while. Aeration shouldn't be a problem as we have these things on a couple of returns called Baja Bubblers, giving a fountain type effect. Hmm...maybe those might contribute to my continually rising pH?
    Does high pH have any effect on chlorine consumption?
    Thanks,
    Jim
    szampino is offline Registered+ Thread Analyst szampino 0
    I kept meaning to ask you if you had some kind of Water Feature in your pool. I used have a fountain and couldn't understand why my PH kept rising. Sounds like you know have a plan.
    Good luck.
    Revived POP
    Intex Blow-up Ring 18x48 round
    Cartridge Filter
    Yup. Turn them off for a week and see what happens! Bet pH is far more stable.
    Thanks,
    Jim
    I don't think it does, (the chem gurus can chime in) but it DOES have an effect on the effectiveness of chlorine...the lower the pH the more effective the chlorine is. But at super-effective levels, your water will be acid enough to melt vinyl (which you don't have).
    I tend to prefer pH in the 7.3-7.5 range for just hat reason. Chem_Geek has tables on that --if you dig around you may find them.
    The graphs of chlorine effectiveness vs. pH with and without CYA are in this post. The bottom line is that with CYA in the water, it acts to buffer the disinfecting form of chlorine which means the disinfection rate doesn't change that much with pH. Without CYA, going from a pH of 7.5 to 8.0 drops the chlorine effectiveness by around 50% while with CYA it only drops around 15% Of course, without CYA, the chlorine effectiveness is huge so even a drop of 50% isn't a big deal (it's still over a factor of 15 higher at the same FC level when the CYA is 30 ppm).
    There is a theoretical increase in the breakdown of chlorine from sunlight at higher pH since hypochlorite ion breaks down about 6 times faster than hypochlorous acid from the UV in sunlight. Though the disinfecting chlorine (hypochlorous acid) doesn't drop much at higher pH, the hypochlorite ion increases a lot to compensate. With an FC of 3.5 and a CYA of 30 ppm, going from a pH of 7.5 to 8.0, the rate of chlorine loss from sunlight is almost tripled. However, we've never done any experiments with real pools to see if this "theory" actually happens in practice. There have been a couple of anecdotal reports indicating that some effect of this sort does occur. Just remember that chlorine loss has multiple sources and we're only talking about the loss due to sunlight in this discussion.
    Richard
