Thread: What should I do? heres the numbers.....
    Default What should I do? heres the numbers.....
    FC 0
    TC 0
    CC 0 I know to ad bleach, it got burned off.
    PH 7.4
    Hardness 170 ppm
    Alk w/ stabilizer correction 214 ppm
    CYA 20
    Copper 0
    Iron 0
    Total dissolved solids not run
    28 ft round ag. 18k gal?
    I put in 1gal of muratic acid
    2lbs of cya
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: What should I do? heres the numbers.....
    Don't put anymore Muriatic in, your already a touch on the acidic side at 7.4 ph. Check your CYA levels in about 3-5 days, then add more if necessary to get to the correct level range.
    As you already noticed, you need some chlorine....
    The pool store said to ad 2 gal acid to get the alk down. then re adjust the ph.
    what to do?
    You should only add enough acid to get the pH down to 7.0, which drops your alk a little bit, then aerate the pool to raise the pH back up without raising the alk again. Then you add acid again to pH 7.0 to ratchet the alk down, then aerate to raise pH. By putting 2 gallons of acid in your pool with a rather perfect pH, you're now way below 7.0, which is very acidic and can very well damage your liner. You need to retest your pH, add Borax to raise it to above 7.0, and then read the steps for lowering alk that are stickied at the top of the Alk and Calcium forum. Oh yeah, and STOP LISTENING TO THat POOL STORE! Sorry to shout, but they're gonna ruin your liner for you with that kind of advice.
    Better get some chlorine in there....
