Results 1 to 10 of 10
Thread: Never had an algae problem before....
    Default Re: Never had an algae problem before....
    Quote Originally Posted by daisy11 View Post
    The more often you test and add cl to bring your cl back up to 12-15ppm, the sooner the algae will be killed. If you allow the cl to drop drastically from shock level, the algae continues to keep a foothold in your pool. That's why everyone keeps saying test 2-3 times a day and add cl to bring it back up to shock level. The presence of combined chlorine tells you that the cl is still fighting something (algae) in your pool. Keep testing and bringing it back up to shock level 2-3 times a day until the cl level holds overnight and the CC is at zero. Then you can let it drop to normal levels. It may take a few days, a week, or longer, depending on your pool, how bad the algae bloom is and how consistent you are about keeping the cl level up.
    The cloudiness is probably dead algae. As Janet said, keep the pump running 24/7 and it will get filtered out.
    The other thing you need along with liquid chlorine is POP...pool owner patience. It will clear up...really, it will!
    I hope you have a quick recovery from your surgery...and your algae bloom, too!
    Couldn't have said it better--Thanks for saving me and Jan all that typing!
    No problem, happy to pass on the wisdom from you and Janet and all of the other experts here. I've been there, done that....as many here have!
    lisak Guest
    Just wanted to say thank you. The pool is sparkling clean and so far no return of the algae. Thanks!
    Quote Originally Posted by lisak View Post
    That's what we LOVE to hear!
