testing help
I have a 23X test kit - got it in 06 I guess it was.
The CYA test solution is nasty and the salt tester never worked.....have been waiting for the new dripper tips....
The guys are Leslies are telling me one day my CYA level is at 20...which is what I expected since my chlorine would never stay around... then after a couple of pounds of CYA are 50...about what I expected then a couple week later is back at 20....I give up...I need some real numbers.
Same kind of thing with my salt numbers...and they are using strips of some sort - not drops.
Can I get test solutions here or where can I get CYA solution and salt testing stuff?
thanks Kevin
- You may not post replies
- You may not edit your posts
Forum Rules
