Results 1 to 10 of 10
Thread: hayward pump help -
    St. Peters, Missouri, USA.
    Default hayward pump help -
    I got a hayward super pump - original kind - had it 4-5 years now.
    End of last season the pump ran fine - I winterized the system and all was fine.
    So this spring I open it all up - turn on the pump and the thing is throwing sparks and is locked up. I tried to turn the impellor from what I could reach and it was locked up. Tried to turn it on on my workbench and it still was locked up, tried switching it over to 120, from 220 and it was locked and throwing sparks....
    I took it the pool store and the tech said the motor was locked and he could not get it free with a vise grips....
    So - is this motor shot?
    Is this common? Why would lock up over winter?
    Do you all bring in your pumps for the winter or cover/tarp them up?
    thanks Kevin
    Default Re: hayward pump help -
    my hayward (gold colored) super pump was only one season old and it started making noise. i brought it back to dunrite pool and they gave me a new one. the old one had scorch marks in the electrical compartment. these pumps are junk.
    By my local pool store today to get a new shaft seal for a superpump that is just 3 months old.
    Local store said they stopped carrying hayward pumps after 20 years because they started having a lot of problems with lockup.
    Hard to get parts and poor tech support but I have had 2 jaccuzzi pumps and both lasted 10 years each without any problem. Then it was just a shaft seal but thought after 10 years I was do for a new pump.
    Switched to hayward and now 3 months and a shaft seal leak.
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    I had a hayward super pump gold colored too - it lasted 2 years - piece of junk
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    So the concensus is to pitch the motor/pump and buy a different brand?
    I thought Hayward was the 350 chevy of pool pumps, standard, reliable and tuff?
    Wow - not what I was looking to hear.
    thanks Kevin
    mbar's Avatar
    Ashland, PA
    Me too - the last hayward pump I had lasted 7 years, and only broke because I shut my new solar panels off wrong . We did get a new pump this year- it is a hayward tristar. So far so good, my husband wired it so that we can bring it in for the winter. We let the other ones out, the first pump was fine, but the super pump corroded on the inside - must have gotten some water in it. I hope this one lasts
    Northeast PA
