Thread: Phoenix Super Erase
    Shrewsbury, MA, 01545.
    Default Phoenix Super Erase
    Any comments or options on this product?
    I was looking for a metal out product in the local pool store and came across this recently. I have never seem it before.
    I've developed some stains this year which I'm looking to treat. It sounded like a simple product to use as the only requirement was a PH level between 7.5 and 7.8.
    I have a 23K gallon gunite pool.
    Here's the link to the product:
    http://www.phoenixproductsco.com/ter..._Mineral-1.htm
    Google didn't seem to find anything. New product?
    Default Re: Phoenix Super Erase
    Proteam metal magic makes the same claim. It's not true. My guess is that this is a private label product made by Haviland, the same company that makes the Proteam products, and that it is just another HEDP based surfactant.
    Thank you.
    So I wonder, will this be an acceptable product for use with the ascorbic acid treatment?
    Beause the ascorbic acid will bring the PH down would it be acceptable to spike the PH, maybe above 8.0, before starting the treatment?
    Or just find another type of metal out product?
    Thanks again for the feedback.
    Quote Originally Posted by TwistyKat View Post
    Thank you.
    Just about all HEDP based seqesterants say to adjust the pH before use. Don't lose any sleep about it. If you use this product be sure to read the ingredients. It should be a phosphonic acid derivative or HEDP.
    OK, thanks!
  1. cooling the pool in Phoenix
    By hikernut in forum Pool Equipment & Operations
    Last Post: 05-17-2012, 07:54 PM
  2. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  3. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  4. Does anyone know an AutoPilot Installer in the Phoenix area?
    By slater1182 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2008, 11:28 AM
  5. How often to super-chlorinate?
    By adesalvo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-15-2007, 11:30 AM
