If you're going to use chlorine - bleach in the pool and dichlor in the tub - no.Originally Posted by Robin N
If you plan on using bromine in the tub ... maybe. I believe that the Taylor kit can measure both chlorine and bromine. The kit that's sold here is similar to a Taylor kit but measures much higher chlorine concentrations so it too can be used I think. Testing both is exactly the same.
Owning both a pool and a tub I can tell you their both easy with the pool being a tad bit easier. Hot water kills chlorine and has it's own requirements vs a pool. One thing is that you will need calcium in the tub but it may be not necessary in the pool if it's vinyl lined.
People tend to use more types of chemicals in a tub but I really try to keep it simple. Bacteria is (actually can be - not necessarily "is") the problem in portable tubs where algea is more of a problem in pools.
