Re: modifying a safety cover?
Thanks for the info.
We have children - the smallest is 4 years old but the pool area is fenced in separate from the rest of the yard and we keep it closed up when the pool is not in use. I'm not concerned with them getting over there.
We ARE however surrounded by huge trees. Every year if the pool isn't covered once the leaves start falling it's a real mess. Last year I decided to just leave the pool running all winter. I figured I'd go out every day and scoop out the leaves and it would be fine. Big mistake. I would come home to hours of work trying to get them all out. And if I had to work late, or go out of town for a day or two... disaster. Soon as much as I fought to keep up - the pool turned into a swamp.
This past spring it took months to drudge out all the algae covered leaves from the bottom. Then forever to get it clear. The pool is gorgeous now and I don't want to go through all this again. Every year I put off getting a safety cover, but they really seem like the best way to go.
Thanks again.
