It's actual original purpose had several uses, one being a different diameter line. One is usually 1 1/2", and the other 2". Using one of them to plumb the maindrain line into, is just a method some builders opted for. If a pool requires more volume of water to be circulated the larger "hole" accepted the fittings for larger pipe. I was just trying to figure out if that's where your main drain line went. But if it's capped, then we can eliminate that. If it had a black plug in it, I'd would highly suspect that it was plumbed there and was "eliminated".
Ok it's hard to tell what you mean by the description. This was bound to happen.
But consider this next time you look at it. If a pipe is not connected to a multi-port then it's probably not coming from, or going to, the pool. If it's connected to the "body" of the sand filter itself it's probably some sort of drain, or backwash line. The multi-port takes the water from the pump (you can probably trace that line) puts it into the sand filter, the water returns to the multi-port (from the sand filter) and is then put back into the pool (by the multi-port, hence it's name). No piping (usually and with out knowing your exact system), that comes from the body of the sand filter is normally coming from or going to the pool itself. It's usually exiting the body of the sand filter itself to the "outside" in the form of a drainage, or backwashing.
So it's still hard to tell what you have as far as how many suction lines . Between it being broken and you trying to remember what it was like, me not seeing , or knowing the exact nature of the equipment I'm still not sure if you have only 1 suction line and 1 "return line. Or more then 2 of each, or any variant in between.
If you turning a ball valve to keep the water from overflowing, to empty a basket, it sounds like your system might be below the level of the pool. Is that the case with your pump and filter?
Yes I'm speaking of that second "skimmer". I tend to call the square opening at the pool that receives the water the "skimmer", and the "strainer" inside the pump body underneath the window, the "basket". But there is another basket at the "skimmer". The nomenclature isn't rigid with pools. Returns are called "jets" by some and so forth.
Either way that's a good sign, if your system previous to this mess, didn't have bubbles in that "window" then it's a good possibility the suction line(s) are intact. How that was done while there's a main drain sitting down there is anyone's guess. There's obviously a line coming from it, where it leads to or connects to is anyone's guess, it might have been cut underground long ago just below the pump and buried. It could have originally come up out of the ground as an individual line, and when it failed, was cut and buried for aesthetic and/or easier access to the system.
Why have it? That's the bottom line. If it's not working, is a potential failing point in the liner, there's no reason not to eliminate it from the whole scenario. As much as I'd like to see you have it done for free, even a nominal fee for removing it is worth it (for you). I didn't charge because a nominal fee wasn't worth the trade off of less hassles.
Whoa whoa don't be printing out "anonymous" posts from forums, and shaking them in his face. It's hardly a replacement for being there, seeing your system and giving you advice. As maybe a trusted neighbor , boy friend, or other acquaintance might. Some times the last thing a contractor wants to hear is something like: "my father told me...." or "my husband said.....", never mind "this basically anonymous guy wrote to me in a forum that......."
There's a lot I could be incorrect about, or is only partially accurate, simply for the fact that the details of your system are totally unknown to me. I'm going with opinions based on assuming a lot of things. The two holes in the skimmer for example, at the time I was only trying to figure out where your drain line was going. Their purpose and why they're there, was too complicated to get into. They're used for several different things, not just plumbing main drains into, and when they were used for that there was a a diverter valve that sometimes accompanied them. Sort of a buttlefly type set up that sat on the bottom of the skimmer.
I even forgot about that till now. Many of these butterfly valves became detached or broken over the years and pools lingered with virtually no flow from the maindrains. See how relying on what I wrote so far, could "backfire".
Best just to say "I've read". Quote me if you like, but it's not going to carry that much weight with some one who's actually there...
But you are on the right track. Your trying to get a handle on what's going on out there. Ask him to give you a quick walk through. Most technicians don't mind. It's not algebra (no offense) , it's in/out. It's left/right. Suction/Return. But unless someone walks you through it at least once, it can be confusing.
If this goes on any longer, a picture and the parts numbers off your equipment would help us a lot. I still have no idea what kind of sand filter or pump you have. They're all essentially the same, but some are odd, or work differently.
There's just so much I can impart to you, and so much that's going to be entirely accurate with out actually being there. But your trying, and reading.Looking up your part numbers online and reading the manuals (when available) helps too.
Let us know what happens. I'm unemployed right now and going back to school so I've got some free time. It makes me feel much better when I'm helpful and productive. Mowing the lawn only provides just so much satisfaction in these areas.
There's going to be significant patching because you can see the divits in the deep end walls that have developed over time -- this concerns him a little. Still, with the new liner, foam, patchwork within reason, removal of main drain, and restoring most of the pvc's at the pump, he's charging hundreds less than the competition -- $2675. (By the way, I mis spoke earlier--plus I asked liner guy--there's only one incoming pipe that comes from underground with the water-valve that connects to the 2ndary skimmer basket, and then the one outgoing pipe that connects to/comes from the multi-port (not the sand filter as I reported) and returns the water to the pool -- and yes, my pump is far below sea level.
