Thread: Green Pool
    Default Green Pool
    PH 7.6, Chlorine around 3, on a regular basis, using Chlorine Tabs.
    Water temp is about 90* (Arizona)
    Run filter 10 hrs every night, sand filter
    Pool water begins to turn cloudy, then green... we shock it with 2 bags of shock plus, run the filter 24/7, it clears up, then about 1 week later, it starts the cycle all over again, gets cloudy, we shock, yada, yada, yada.
    Any ideas on why this keeps happening?
    All tips/advice are appreciated.
    Default Re: Green Pool
    A few questions:
    -- I assume the chlorine tabs are trichlor?
    -- What is your cya reading?
    -- What is shock plus - meaning ingredients. I suspect it is dichlor.
    -- What type of pool (vinyl, concrete, etc.)
    I'm pretty sure I know what your problem is. Those tabs are most likely trichlor which is stabilized, which means they add cya. Dichlor also adds cya. Over time, cya builds up and you have to run higher chlorine levels as a result, which most people don't realize. Thus, algae takes over.
    Repost with answers to these questions and somebody will help you from there.
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 11:25 AM
  5. green green pool
    By mr greenpool in forum Dealing with Algae & Slime
    Last Post: 07-09-2006, 02:04 PM
