Results 1 to 8 of 8
Thread: Three months in the program
    Default Re: Three months in the program
    Yeah, ain't it funny how uncommon "Common Sense" is? I've been using the B-B-B method for 8 years now and as I've learned more and more I'm amazed that people still doubt its effectiveness. The chemistry is unimpeachable.
    I just came back from a two week vacation. Everyday I had my father-in-law dump a gallon of 6%/7% in the pool--I left him enough jugs. I kept the pool covered and the filter on a timer. He had to add water once, but the pool was clear and clean and warm.
    Carl,
    I can top that. I went away for 12 days in July (in Florida). As you know I keep 50 ppm borates in my water. I just shut off the pump and SWG (no one to keep an eye on the pool), shocked to about 20 ppm, and hoped for the best. I came home to a clear pool so I just fired the system up, shocked it again, and all was good!
    Scottsdale, Arizona
    Evan , I'm curious why you shut it down completely like that? I go away for 1-2 weeks at a time multiple times during the year. A very high PH is typicaly the only thing needing corrected when I return.
    I do have to use an aftermarket auto fill device to keep the water level at the proper level.
    Are you concerned about a failure in the equipment ?
    I don't have autofill and get a lot of evaporation here in FL. I knew the water level would be low when I got back, probably too low, which it was. I decided shutdown and possibly a green pool (which is an easy fix, really) were better then possibly a burned out pump.
    Since I've added borates my pH stays very stable and is rarely a problem.
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    I'm on my 3rd season, and have never had to shock my pool. I love my SWCG.
    This will be my 5th year on BBB with only $15 of chlorinating liquid monthly (during the 7-month summer swim season) for my 16,000 gallon pool, no shocking, no other chemicals (except a small amount of acid once a month). This is in spite of my pool having 2000-3000 ppb phosphates. The truth will set you free (of labor and headaches) and keep your wallet full.
    Richard
    I shock once in a while, but very rarely and think nothing of it. Mostly I just keep the levels pretty constant. Last year was a big bleach year--but it was for EVERYONE in the region, so it was the weather.
    I never measure or care about phosphates. The day I have an algae problem I can't cure is the day I'll worry about them. In the meantime, I'll continue to preach that phosphate prevention programs are programs to prevent your wallet from getting thick.
    In these tough economic times it's important to NOT waste money on stupid lies and scare tactics designed solely to separate that badly needed scratch from its earner--YOU!
