Thread: Is there such a thing as purple algea?
    Wisconsin
    Default Is there such a thing as purple algea?
    The pool is starting to form something on the sides and bottom that looks like a purple colored algea. Is there such a thing. It's slimy and purple, and the chlorine is starting to get eaten up. I'm shocking and vacuuming, but I have never seen anything like this. Thanks,
    37,000 gallon IGV
    Default Re: Is there such a thing as purple algea?
    There is such a thihg as pink slime or pink algae. It is actually a bacteria. If you have a blue liner it might look purple.
    Wisconsin
    Can you ever really totally get rid of it? Every time I think I have this beat, it comes back. Not real bad, but it does keep coming back. Any idea what causes it?
    Thanks,
    too low a chlorine level causes it. It's hard to get rid of and takes very high chlorine levels. If you have high CYA than a sodium brominde based product (along with a LOT of chlorine) can be effective.
    Wisconsin
    Thanks Evan.
  1. Bright blue to light purple water
    By CabanaMan in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2008, 07:57 PM
  2. Jacks Purple Stuff Alternative
    By Simmons99 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-01-2006, 12:58 AM
  3. Jacks Purple Stuff Alternative
    By Simmons99 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-30-2006, 03:53 PM
  4. Jack's Magic Purple Stuff for SWG?
    By johndoe74 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-16-2006, 04:24 AM
  5. Jack's Purple Stuff Questions
    By mkamp1515 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:13 AM
